Vac line help needed
I am busy trying to figure out why my heat is always on and my first thing I am checking is the vac line to the heater control valve. But I have no idea where or what that looks like. But while I was in there looking around I have several vac lines that are not hooked up to anything, and I have no idea where they belong... If anyone can help IDing the lines and what the valve looks like that would be a huge help.
First line I noticed was this one which comes from a three way connector under the intake near the cyclic valve, then it comes up to the firewall makes this bend and just ends.
Here is a picture:
![](http://img70.imageshack.us/img70/9923/0707082248bc0.th.jpg)
Next is this line coming directly off a banjo on the intake, and abruptly ends.
Here is a picture:
![](http://img519.imageshack.us/img519/5426/0707082250wj6.th.jpg)
ok well this one goes to the fuel pressure regulator as shown- but it should also have some other connections IIRC. Not sure about the second one i only remember one hose coming from right there for the vac. canister. Lemme see if i can dig up the vac diagram- search is your friend.
Check the clip above and to the right of the gas pedal. It's a $0.79 clip that breaks frequently with age. A zip-tie will work as a quick fix if it is the issue. Also check the vacuum lines near the heater core hoses on the passenger side of the firewall. There should be 2 of them going through the firewall. AND last but not least, near the middle of the firewall is the heater control valve that also has a vacuum line going to it. The valve is known for failure and it a REAL pain in the **** to replace unless the intake manifold is off. Sounds like a good time to get in there and do some cleaning if that is your issue.
Good Luck.
Good Luck.
ok well this one goes to the fuel pressure regulator as shown- but it should also have some other connections IIRC. Not sure about the second one i only remember one hose coming from right there for the vac. canister. Lemme see if i can dig up the vac diagram- search is your friend.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Thank you kind sir.
Also I have been doing a lot of searches and reading and can't find anything about a vac canister... I did however stumble on a picture and I think I see the line not making that "U" Here is the picture that I found.
![](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/247723d1200799123-hvac-vacuum-help-heatervalve.jpg)
As far as the line to the fpr goes, I must of knocked that off while trying to hook up some other lines, I have a feeling it wouldn't run very good with that one off.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
EDIT:
I just looked up under the dash and I see nothing that resembles a vac line near gas pedal. Closest thing is the hood release line...
