Headliner coming apart - need help
So today I decide to take off the roof because the weather is so nice. I notice that the rubber seal on the body (not roof that comes off) is pulling off and the headliner is falling down. Its not that bad yet, but I would like to fix it ASAP.
What adhesive would I use to fix this? It gets 95 to 100 degrees in the summer so it needs to be able to withstand some heat.
TIA
TIA
For your headliner use a contact glue. NOT 3M or anything out of a spray can. Goto an uphostery shop and have them use their glue. It is industrial strength like from the factory. If you were closer I would fix it for free for you. 2second job. I do auto upolstery and do these kind of jobs alot. A shop in your area can do the same for you.
