converting a non-LSD gearbox to LSD?
Quick question:
Trying to determine what's needed to convert a non-LSD gearbox to LSD. Archives search was inconclusive. A review of PET suggests the carrier between a LSD and non-LSD are not the same.
Why you ask?
I have LSD unit that is showing some issues with the output flange. Wondering if I get a replacement (used) gearbox if I can stuff in my LSD core or if there are other internal part swaps required.
Yes, I track the car and want the LSD.
Why you ask?
My understanding is the output flanges are integral to either the non-LSD or LSD design.
Short answer: you can swap an non-LSD in with no problem; but you can't use the non-LSD flanges on an LSD differential.
So...the "value" of an LSD unit is not the entire gearbox itself so much as the LSD 'insert'?
And...of course a correctly setup diffy assembly as noted by Phil?
BTW, I talked to the folks at Guard the other day (who rebuild LSD unit) and they thought that R&Ring a 951 LSD unit was about $400 assuming that the 'ramps' where still usable. According to them they most always are. I thought that was pretty reasonable.
I ran an LSD without a cooler (as did several Previous Owners of the same car) probably 2 dozen track days.
When I had my car at the track in April the guts of the LSD disentegrated. Every gear and shaft in it broke.
I think I'll run one with a cooler now.
Update: Information from Mike at Guard.
The carrier is specific to the LSD unit. It has a special cuts, markings, pins etc that tie to the LSD unit and trigger the friction plates.
