951>>> High Bar Reading!
my 951 shows 1 bar all the time now, on start up, 1st - 5th gears
what could be wrong?
I know I need a new BOV because mine is the stock one and it has 178,000. It blows out the pressure at very little boost
Not sure what is wrong!
thanks in advance
thanks in advance
![](http://www.rints.com/hammond/images%5Cengine022701.jpg)
The clear (yellow in the picture) plastic line (pointed towards the firewall) in between the #3 and #4 intake runners is how the KLR senses boost pressure. I'd start by following it (or replacing it) to see if it's broken or disconnected.
Probably a faulty gauge - AFAIK it's an electrical gauge driven by the KLR. Mine sometimes shows 1 bar on start up & can take 10-15 secs to start working. I put that down to deteriorating wiring in the instrument panel.
Hook up a mechanical boost gauge to the inlet manifold at idle & you'll soon be able to find out.
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
30 bucks from 944online.com.
Yes, if you cut it and taped it together, then I am sure it is leaking, and your boost gauge will read wrong. For the record, that line just comes undone with the twist of the little black compression fitting on the KLR itself.
I just bought a nice porsche style VDO boost gauge from ebay for my project ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://cgi.ebay.com/ebaymotors/ws/eB...m=160251336435
![](http://i10.ebayimg.com/01/i/000/f7/6f/2fb6_1.JPG)
I like the porsche stock needle style.
it will fit nice in with this oil temp gauge![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
