Need help with where negative battery line grounds to engine???
Okay so i am almost done with putting my engine all back together and i cant seem to figure out where the wire that comes off the negative side of the battery and goes through the firewall on the left side connects to.
It would be greatly appreciated if you could help me...
Oh and after the firewall the line is about 1.5 feet
Chris
Chris
It goes to a point on top of the bellhousing. Trust me, just fought trying to get it off a few days ago because I'm doing the clutch. I ended up cutting it and I'm gonna ground it somewhere else. Not sure why porsche thought it was a good idea to ground it all the way down there.
i thought that was where is went but isnt that where the two brown gournd wires go.
one is a little bit bigger with a larger eye and the other is smaller with a smaller eye...
are you guys saying i put the black wire that comes off the negative side of the battery over the bigger brown wire and ground then both there?
chris
chris
