Enlighten me on injectors.
Just a quick question.
If an engine is being tuned and modified for, say theoretically 300 HP at the crank at 100% duty cycle injectors would need to be about 43#/hr at 12:1 AFR.
If 55# injectors were installed in this setup, assuming the same AFR of 12:1 would the injectors need resistors? Also what approximate duty cycle would that be?
Thanks.
Thanks.
Official Rennlist
Borat Impersonator
Borat Impersonator
Thanks.
Thanks.
the drive was a blast! flying up palomar mountain was a workout on the hairpins without power steering...average speed up the mountain for the group (about 20 cars) prolly around 60 or more.
preparing for a build...
You need two 1ohm resistors (one resistor on each injector wire coming out of the DME).
Defending the Border
Rest In Peace
Rest In Peace
This is the rig I built, heat sink may be a little over the top, thermal paste included. The sink does help protect the assy. I got all my info through search.
Resistors are easy to install and required for reliability with low impedence injectors.
The ECU driver is rated at 16 amps.
Without resistors:
0.625ohms. 12v/.0.625 = 19.2amps.
With two 1ohm resistors:
2.5 ohm + .5 ohm resistance(a 1ohm resistor on each of the two injector dirvers) = 3 ohms each
4 injectors would be 3ohms/4 = 0.75 ohms
12v/0.75 = 16 amps.
I'm running on 3 hours of sleep this morning so if the above is wrong, please correct.
...and with that, here's where I installed mine:
Without resistors:
12v/0.75 = 16 amps.
I would suggest either mounting them under the dash or near the battery if you don't want them inside.
