Making larger turbos fit
#31
Got the crossover to turbo bolts in too, had to loosen EVERYTHING from the exhaust manifolds to half way back on the exhaust system.
Thanks for all the advice guys. I don't know how I would do all this crap without Rennlist.
#33
Everyones talking about having trouble with the factory turbo mounting screw so i figured i would share how i do it with the factory bolt. Take an ordinary allen wrench and cut as much as you can off the short end while still having something to grab into a bolt, then turn the wheel a little till the u joint moves enough to get the wrench on. It's worked for me on a few of these cars.
