Saiko Michi question
Official Rennlist
Borat Impersonator
Borat Impersonator
I know that using other catch cans some of you drill the AOS hole to make it bigger, should I do that if I'm installing the saiko michi?? If so, what hole do I enlarge??
when you pull the hose off the top of the AOS and look down inside the can, you'll see that the hole is not drilled out completely. I did not do this to Sam's car when we installed the catch can and it works fine, some say to do it for the Lindsey can though.
