Can somone explain camber plates to me?
So is it possible to just have an alignment done where they set the camber to say -2 degrees, and have no toe on the car, as to preserve tire life? Or are the two in proportion to each other?
The point of my last post is to note that if you ADJUST one, then the other changes AND the amount of that change depends on yet a third variable, the amount of Caster you have.
From a practical standpoint, what one would probably like to be able to do with a street driven car is to easily change from track to street setup, adjusting only the camber via a readily accessible "tool" (the camber plate). Unfortunately, since adjusting Camber affects Toe, Toe also needs to be re-set to the desired angle, especially since it's excessive Toe (in or out) that has the greatest impact on tire wear.
Setting/Re-setting toe isn't really that big a deal (toe-plates are probably the least expensive alignment tool) but it is an "extra" step... that can lead down that steep slope towards a dedicated track car, trailer, tow vehicle...
what you need regardless of plates or not is a "good" alignment. most shops just set your car in "spec" which is a range. you want your car set to specific adj. not the allowable range, a good shop will do this they will also charge for it, it's time consuming-no 89.99 alignments.
Unaffiliated
One more item.. On a stock TS suspension, you can only get about -2.5 camber. My track Hoosiers were wearing the outsides off, as the manufacturer recommends -3. I bought the camber plates, dialed to -3, problem solved. BUT..I also added those Mo30 968 Sways. All of a sudden I was wearing the INSIDES! Back to -2.5, all fixed. My lesson-stopping body roll will reduce your need for negative camber, and maybe even save you $400!!
