The MegaSquirt2, with its circular connectors. High density for sensors, other one for high current (mainly the coils, 15 amps per coil x2 coils ). All going into the larger case, which will have multiple circuit boards in it.
The new mil spec wiring harness. Tefel covered wire, the Autosport connectors, etc etc. All the heat shrink that will cover it hasnt arrived yet, so im just laying out the wire.
My lame temp mount for the fuel pressure sender. Itll get mounted better :lol: Can see the connector partly filled. It wont be full up for a long time, im leaving space for multiple EGT sensors, wheel speed sensors, etc.
where did you get that filter/intake pipe? is it 3" at the turbo inlet?
I bought it used off someone on here, I think its the old style that SFR sold with Link Map piggybacks, but im not positive. Id have to measure when I get home tomorrow but its 2.75" or 3".
Some really nice stuff you got there!
But why install the engine without assembling the complete bottom end first?
Im waiting for the windage tray and new oil pickup, so im going to drop the engine out once I get those. Takes me 15 minutes to drop the egine when its like that I wouldnt have been able to lay the wiring out and get the right lengths as easy with it out.
