Autometer boost gauge issue - Help
So while uhh.... doing some testing, I seemed to have knocked my boost gauge needle off when it hit the pin. Hopefully the gauge comes apart so I can stick it back on.
My question is, where does the needle sit when not in use? There is a box by the 0. I think mine used to sit at the top of that box but I want to make sure.
I found an old pic that looks like it did sit at the top before however I also did a google image search and some I saw had it at the bottom of the box.
Then this one is kinda in the middle. I am thinking now each one is different based on how they are calibrated from the factory. I am going to try to put mine as close I can tell to how it was originally. I can check the calibration by comparing it to my AVC-R. I just don't want to have to take it apart again if it's off.
UHH don't you hate it when that happens. Thats what you get for using too small of a boost gauge
another thing to note is that they are calibrated to atmosphere, the needle could be anywhere in the box depending on your elevation On mine it is on the low side.
Actually that is the one I am using now. Thanks to Troppo
I took my gauge apart and stuck the needle back on. These gauges are not designed to be taken apart by any means. It's all back together and appears close enough to what it read before at a set level on my EBC.
Ahh I didn't even think of that. So since it's a mechanical gauge, they are probably all the same at the same sea level but since some of these pics I found were most likely taken at a different sea level, the gauge will sit at a different spot in the box....
Ya know, Auto Meter's quality has really taken a **** over the last few years. The first ten years of me being into cars I wouldn't even consider anything else but it seems that I've replaced more broken ones in the last five (three actually) years then I installed in the first ten.
Small Business Partner
I have the exact same gauge. I spiked well over 30pis when my wastegate line blew off. Fortunately my gauge needle stayed intact. And I still had barely any knock - got to love E85
-Rogue
-Rogue
When I called AutoMeter a few years ago regarding the a/f gauges, they were complete ********. I just called again a few weeks ago regarding the boost gauges, and they were pretty cool, stating that there would be very little or no charge to repair them.
Because it's you. Had it been me they would have charged me double. See if you can get my water temp gauge back into calibration.
