Cleaning the ICV - looking for advice
Odd Posts
I am in the process of doing a venturi delete and replacing the cycling valve and hoses. I figure while I am in there I should clean the ICV. I have no issues with idling right now, but given that the intake manifold is off....
I would greatly appreciate any advice on how to clean it.
TIA
TIA
It's very simple, spray copious amounts of brake cleaner into it, let it sit for a while, drain & repeat until clean. Final drain you should make sure that it all comes out. I would suggest that you replace the two rubber supporting mounts while you are there. They are probably about to break anyway, or you will break them removing the ISV.
