flunctuating and high idle, Any ideas?
smoke test or not. I think you missed a vacuum leak. do you have a manaul boost controller? line going to WG burnt/rubbed through? just an example of the many ways you can miss the leak. line going to KLR broke inside car?
hope this helps and you find it.
I preformed the test on the TPS unit by rotating the throttle cam open and then alowing it to close slowly. Not a sound, no clicking, repeated 4 times nothing .Bad TPS unit or mispositioned TPS unit. Thanks.
wierd. still havent found it, however a buddy of mine jsut bought the car from me and now me and him together are going to fix the problem. thanks for the help guys.
