Anyone install their Lindsey catch can with intake manifold still on?
I see its 'recommended' to remove the intake manifold to install this, but has anyone done it without doing so?
Any tips if you have (pics)
Otherwise I guess I will wait to remove the intake
Intake is easy to remove. I had to pull mine last weekend, and was pleasantly surprised. The whole lack of water running through it, like most cars, is a major +. I'll pull mine again this weekend to check the AOS.
I have installed 3 of them without removing the intake. 1 each on a '86, '87, and '88. Just need flexible fingers and an assortment of stubby screw drivers or ratchets. This went along with the venturi delete and ICV replacement on the '86 and no cyclic valve on any of them so I had more room to work.
