I need a right (passenger) side ABS trailing arm for a 951
I am looking for an 87-89 951 trailing arm with the hole for the ABS sensor. It would be helpfull if it has the parking brake included. I have a non-ABS arm and don't really want to drill out the hole and drill and tap for the retaining screw.
Colin, I see you're in South Carolina. Whereabouts? Just look on the top of the arm behind the rotor if it has about a 13/16 hole drilled all the way through and a second drilled and tapped hole for the retaining screw its ABS.
