FS: 951 MAX Chip new $199
I have a 951 MAX chip I purchased from Lindsey Racing. I sold the car, so I don't need the chip. Never installed it. Never even opened the bag. May loss is your gain. Set up for 26/6 with stock injectors. $199 takes it. PM me if you're interested.
Still I dont believe the wastegate matters, what matters is what psi the chip level is mapped for. As long as you have no vac leaks or anything broken and the chip is mapped for 15-16psi, then you should not run lean whether at 3000 RPMs or 6000 RPMs (if you can hold 16 psi to redline with stock turbo, there is a long thread on this right now )
+1 buy it
Ian, When buying russel's chips I don't remember the wastegate being a factor in the chip map options. What you need to know is which exhaust its for (2.5" 3", cat no cat etc.) and whether its a 12-13psi burn, or one for 15-18. He already stated the turbo and injectors, I believe thats all the options. You can verify this by going to LR website and starting to order the chips online.. They will make you option the chip.
You will also need a 3bar regulator if you don't already have one. I just recieved my MAX chips last week, but I'm laid up waiting to have a body shop delete my cutom turkey buzzard holder / left headlight domination. I can't wait to see how they do!
On a side note, did you ever decide if you are going to stay in the Columbus area?
Once trackjunky has sold
For sale - Max951 chips for sale with following configuration
1986 951
| Air Flow meter - stock
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 34.6# injector (stock)
| 15-18PSI Boost
These were in car less than 2k miles.
ran 156.998 mph at Bonneville with this chip
reason no longer used is upgrading to Vitesse stage3 turbo kit
these ARE NOT FOR SALE until trackjunky sells
1986 951
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 15-18PSI Boost
1986 951
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 15-18PSI Boost
1986 951
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 15-18PSI Boost
-Darwin
1986 951
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 15-18PSI Boost
1986 951
| 3" exhaust - no cat
| K26/6 turbo (stock)
| 15-18PSI Boost
I'm a jerk. I'll lose $50 bucks on this chip in less than two months. Good thing I'm not a business man.
