Pulled the head today
#46
David,
Did you use any type of sealant on your head gasket; assuming you went ahead with the MLS. Are you using OEM head studs? I will be installing a MLS head gasket with some raceware studs some time this week and just wanted to get some insight.
Thanks!
biggles
Thanks!
biggles
#47
i usually flush with plain water, that is as long as the coolant came out clean, if not go to a napa and get some pro grade stuff-motorvac makes a good flush conditioner. FWIW i've been using blue oem volvo coolant
#48
If c/r = compression ratio, then it's been a while, but it was 149/150 psi 1000 miles after build.
#49
No sealant just clean and dry, reusing ARP's last torque to 90 ft lbs
#50
if that's the case use a good flush followed by straight water, you might have to do straight H2O a few times till it comes back clear. then fill with a quality coolant. did you change it regulary?
#52
At least thats the way Audi has the idea. Just something to think about with all the efficiencey testing i read up a while back (ducting, fans, blah blah)
On another note, I hope you can keep this head and block together for a while! Lots of HG issues lately
#53
Im under the impression that you want to feed the core of the IC. Ie duct around the entire perimiter so air flows through the center portions?
Some think if you vent the header panel you create an exit for air, not an inlet so I constructed a divider between the stock inlet and the cut header panel, so none of the air from the stock duct can excape thur the header panel if that's the case. The perimiter is sealed.
Then the hood is vented to help move air thru the intercooler and engine bay area.
#54
The coolant in the car was 2 years old, the leaky headgasket cause contamination.
#55
Speak to me....
Some think if you vent the header panel you create an exit for air, not an inlet so I constructed a divider between the stock inlet and the cut header panel, so none of the air from the stock duct can escape thur the header panel if that's the case. The perimeter is sealed.
