balance shaft alignment question
Could someone please answer this question. Upon aligning the lower balance shaft, do you align the rectangular shaped opening with the "O" visible through it with the notch on the back belt cover or the notch on the back side of the shaft itself? Thanks!!
Thanks! Except the notch on the belt cover by the top shaft looks more like 12 o clock? Clarks manual states that it's closer to 1 o clock. I'm a little confused
