Spring Plate: Bolt head size?
Anyone have this info handy?
What's the size of the bolt heads on the two bolts hold the spring plate to trailing arm? One a support bolt and the other is a ride height eccentric.
Nut IIR is 22 or 24mm (have the right socket) but I need a wrench to get on the bolt.
TIA!
Jeff
TIA!
Jeff
UAE Rennlist Ambassador
The eccentric head is 36mm and the support bolt is 24mm
Both locking nuts for those bolts are 24mm
PS: You need the special thin 32/36mm wrench from porsche or make you're own. A standard one works fine, but could give you problems with gripping the bolt heads.
