CArbon door cards
Ok great thanks for the translation.
Composites is part of my profession and I foresee making a carbon door panel to be a real bitch. You could reduce noise quite a bit by introducing foam between the door and the panel, and by making sure it bolted down in quite a few places. But the real trick would be to make it look right.
Easiest way to do this would be to simple lay up on top of an old, junker panel. Then again, you'd have to deal with the handle (which can be solved relatively easily).
If you want to go prepreg carbon, you'll be paying a huge amount for something that's just not really all that necessary. Only real advantage is that you'll be doing less sanding at the end.
