Lightweight Factory Sunroof Modification Attempt #1
I tried thinking of a way to make a lightweight sunroof, but the curvature and the means of attachment proved difficult. So I figured I'd work with what I had and attempt to lighten the factory sunroof.
I started with this factory sunroof with manual latches.
![](http://forums.rennlist.com/upload/sunroof_mods_001.jpg)
Pulled off the aluminum strengthening strips.
![](http://forums.rennlist.com/upload/sunroof_mods_005.jpg)
Trimmed off all the excess fiberglass ridges with a dremel tool. I retained the mounting points so I could still use the manual latches.
![](http://forums.rennlist.com/upload/sunroof_mods_007.jpg)
Sanded (not perfect, but no one will see it anyway), and painted.
![](http://forums.rennlist.com/upload/sunroof_mods_008.jpg)
It went from 18.5# to 9#, including the seal and latches. While not as light as the GT Racing fiberglass sunroof, it didn't cost $260 + shipping. In fact, it didn't cost anything but a little spray paint. Plus I didn't need to paint the topside, or figure out a method of mounting. I'm pretty happy with the results, and this mod dropped me below the 2500# mark (no lexan windows or fiberglass body panels)!
Looks good. Have you thought of permanently bolting it in place? Buddy of mine rolled his 951 at Nelson Ledges a couple years ago and the sunroof was popped into the car. Went just behind his head and landed in the backseat.
Are you still running a glass rear hatch?
jim,
you've got to come clean...i thought you were running a fiberbglass rear bumper!
i've got some work to do to get mine lighter!
good work on the sunroof
greg
greg
Yes, factory glass hatch. I'd like to go lexan, but swapping out the hatch frame sounds like a nightmare.
![order](https://rennlist.com/forums/graemlins/order.gif)
I think that front bumper is polyurathane, or something. It's durable and flexable, but it's heavy! If you're really looking to put the car on a diet, that's one place to look (plus you can reduce your polar moment by removing weight far away from the CG).
Hey thanks for the great idea. My ideal driving position w/ the factory sport seats puts my head thru the roof when I wear a helmet. So, I want to trim down a sunroof and run with that at the track. Great heads-up (no pun intended).
