89 951 failed CA smog
Come to think of it I probably screwed it up back in NJ when I picked up a few tanks of Sunoco leaded race fuel.
This won't help with a bad cat, obviously.
Excellent point..........
I can only speculate here but you may be on to something.
How does one find out whether or not it is a California model?
Thanks for all the replies....
I will be trying a few common sense items.
I dont want to go out and spend big $$ on her since imho she does not really need anything.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
I still do not agree with the way CA smogs vehicles.
I guess if we let the goverment have its way we alll will be driving at the proper speed limit and no emissions.
think obd III
think obd III
Did you put all your stock crap back on before all this?
IF you do end up getting a cat, have it designed in such a way so that you can remove it and install a test pipe in its place so that you can store your Cat and not destroy it. Although then you wouldnt be street legal and could get a ticket, however i've never heard anyone getting ticketed for something like that.
My OEM cat is waiting for next november... we'll see what happens :-)
I had a hard time here in Wisconsin. We have an IM240 dyno test that runs the car at various speeds. I finally passed with the original cat (178K miles). I ended up replacing the O2 sensor, DME temp sensor and dialing in the idle fuel mixture at the AFM. I think that a previous owner/tech adjusted the AFM with an old O2 sensor, so it failed when I replaced it. Just a guess.
