Wideband A/F question
I have my WB O2 (innovate installed) at idle and driving w/o boost stays around 14 -15
but under boost drops to 8-9 which seems too rich or is this needed under boost?
BTW running Guru chips at 15 psi.
Steve
Steve
I kind of fiqured such. I am about to install Tims blow thru MAF, which uses the Split second as a fuel controller. Would I be able to bring the a/f into the 11's?
I plan to upgrade to Russels Maxtronic or his chip set, as he is the only one who will tune this MAF.
Steve
Steve
Thanks for the input, I installed the innovate last week, it reads 14 -15 most of the time, and around 22 on strong decelartion. Is is possible to only give wrong reading on boost? I will call innovate today.
Also when under boost I can definatly smell the ehaust but that may me normal
Steve
Steve
what kind of recirc/BOV do you have? Mine had a rich spot when i would let off the gas after hard excelleration and the recirc valve had a bad seal. Then i put a BOV on there to try out and it was adjusted too loose and she was going into the 9's under any kind of load or boost. SOunded cool though :P Eventually i just put the recirc valve back on w/ a new seal. It still shows slightly rich but according to my ZT2 logs its just when i let off the gas for a mili second.
Right now I have the stock valve, When I let off on heavy accel, the readings are around 22. It is when under boost the readings stay around 9 until I let of accelerater.
thanks
Steve
thanks
Steve
Sounds like you've got a boost leak to me.
I was dipping under the 10s for a while until I just sat down and examined all possible areas for boost leak (intercooler piping, mainly). Turned out, a hose clamp wasn't event tight.
Now, my AFRs are around 12:1 at full boost. And FWIW, I was at stoich under steady accel and all that jazz, because there wasn't enough pressure to induce a leak out of the boot. Once the turbo kicked in, however, all pressure left through the leak.
Check for leaks.
Check for leaks.
Check for leaks.
Check for leaks.
Steve
