Project assistance needed (cam tower removal)
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Ouch, that is a MAJOR pain in the ***.
The only way I could fix that was to get a cold chisel and bang the crap out of the bolt head until the part of the alen key would come out. Its just about usless to try and drill it out - the key is a lot harded than the bolt head and the bit will keep slipping off.
Forgot one thing...
Where do I get replacement studs? Should I replace them? I have seen many have snapped them during pump removal.
I am getting the WP mount kit from Paragon that includes bolts but not studs.
You have an '86 Turbo, so you already have the 'updated' water pump. The update was on non-turbo early cars, which was merely a turbo water pump and a block off plate for the turbo cooling outlet.
Am I off base here?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If its still the original part then it won't have the guard. If it is the original pump have it bronzed - its a collectors part! They usualy don't last this long!
I'll have to check my '86 now, the PO replaced the pump, so hopefully it's updated. I've got the updated pump on my '83 though
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Jane Bond 007
