Do these lights sound ok
I am thinking about putting in 100w/130w in the headlights, 55w in the fogs and modifying the fogs where I can have driving lights in the other side (getto euro) and putting 100W bulbs in there.
I am going to make a custom harness with 4 ga wire feeding it so power wont be a problem but are these wattages ok assuming I have all the power I need?
i have a set-up similar to ice shark's(god rest his soul) hella e-code lenses 100 watt bulbs relay fed.
european driving lamps 100 watt bulbs never run these at the same time as the fogs housings will melt.
i have no idea as to the lumens but ice shark posted his set-up and it was insane.
Only two or three... I think
and they each have there own unique question that is not found via search. I promise its the last
. But is what wolf posted true, will the fog housings melt if the 55w fogs are on as well as the 100W driving lights?
I think it should be fine, but would like to know a definitive answer from anyone that does it.
IIRC ice shark posted it, it may take awhile to find it though. european cars had two switches for the fog/driving lens, fogs only worked with the low beams and high's only with driving lights. let me look
