Alt belt won't stop slipping
This happens when I first start the car or when I put the headlights on. I replaced the altenator and ps pump belt but if there is any extra load on the alternator it starts sqealing. I have replaced the ground cables as well. I even tried belt dressing. With no extra load it's fine but if it's cold and I apply breaklights at idle it starts again. Needless to say I need some ideas....
Ok after making sure you have the belt tensioned enough, take a look and make sure the upper mounting bolt in your AC is still there...
Don't ask how I know.
Same symptoms as yours that went on for MONTHS. I would buy a new belt and crank it up tight and that would last for a while then SQUEEEEEL it would go.
IPSC
IPSC
IPSC
IPSC
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Check it! IPSC is probably right.
Ok, I checked the bolts and everything is there. The belt did loosen up some from when I installed it, so I retightened it and it is holding for now. I guess I will see how long it lasts.
I got underneath the car to check it. I unbolted the adjustment rod from the compressor and it was still bolted down firmly. I was never able to use the a/c because of the belt. Now that I tightened it, it is holding with the a/c on.
IPSC
Apparently the belt had stretched a bit. When I first put it on I made sure it was tight enough. I don't remember the brand. I got it from the FLAPS. It was the more expensive one they had. Since yesterday I have had no issues with it. Thanks everyone for the input.
