If you're going to vent to atm
you might as well slap this on the end and duct it back into the system
http://http://www.airtxinternational.com/how_vortex_tubes_work.php
-40 degrees!
or just plumb this in there somewhere
http://www.airtxinternational.com/ca...amplifiers.php
30-1 pressure ratio!
-40 degrees!
Yep, you can put a small orifice in a piping system and it will cool the charge as it flows to the lower pressure side of the orifice. This is generally the principle behind refrigeration. However, these small orifices or as NASCAR calls them restrictor plates, do decrease flow considerably.
Quicker spool?
IPSC
It may be cold air coming out of that thing, but it still is exhaust gases so there would be no point in routing it back into the intake (if that is what you're talking about).
Drive-by provocation guy
It would all depend on how much the flow would be restricted.
Well, an intercooler is basically the same if you think about it.
It is a large restriction to airflow that offers a pressure drop and cools the charge. But the cooler charge air far outweighs the restriction.
I'm not saying that other piece will do the same, but in theory it seems much like a miny IC.
