Vitesse Sale Event - RennList Special
John's products are top notch, as is his service, and I will be happy to vouch for both. I am EXTREMELY pleased with everything I have ever purchased from John, and there's more than one Rennlister who have ridden in my car that will be able to verify the performance of my 951. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Vitesse ROCKS!
Regards,
Vitesse ROCKS!
Regards,
Great sale.
If I had to do it over again on my 2.5, I'd still select the stage two as "in my opinion" it's an outstanding street turbo package. A few weeks ago a group of us went out with the cars and I put a beating on my wife driving my 400WHP ZO6 @ only 17 PSI on 91 octane. This was shortly after the two of us embarassed a 997S (a few times).
I've been in super 75 cars, Vitesse stage 3 cars, 27/6 Cars, GT25 & GT30 cars, and I still believe the stage 2 is a better choice with respect to spool up and delivery for a street car. You can't beat the out of the box plug and play package of the Vitesse Kit. With race gas I can still run 25 psi for the fun track days.
Does the stage 2 turbo beat the K26/8 with respect to both spool up and delivery ?
Spool is about the same (I see 15psi by 2950) but delivery is much more linear. @ 5K rpm's in 2nd gear under full throttle I break both tires loose with 275's and a fresh suspension. 1st can be useless if you let it and a bit of throttle during a third gear shift keeps them spinning. On occasion it slips my new cup clutch on a fast shift in the upper gears.
I take it the only difference between the St2 and St3 is the size of the turbo with the stage 3 being a larger unit? I'm guessing the MAF and piggy back are essentially the same?
Scott & Jeremy, thank you for the kind words. I'm glad you like your Stage 2s..
Thom, as Jeremy responded. The Stage 2 is very fast spooling (someone had a video showing 6psi boost at idle, just revving the engine - I don't advise it). Stage 2 is capable of supporting 400rwhp, I would say this is a bit more than the K26/8. It's a different feel, you have power on demand, and very linear.
sawood12, you are correct, the main difference hardware wise between Stage 2 and Stage 3 is the turbo.
I can't speak about the Stage 3 turbo. Mine is lying on a bench and I won't be able to install it before several months...
But the MAF (without PB) is a great product. Great spool and driveability, idle is perfect and as it has already been told, John provides a great customer service and is very helpful (I wonder if he ever sleeps
Well, let me give my numbers from the Dyno today on my 86 with John's MAF, 75# injectors and FPR. I do have a shimmed factory wastegate and MBC. Other than these Mods, the car is Stock, no other bolt-ons or internal mods. I made 245WHP and 276WTQ, this was on a Dynojet. The car has just over 100K on it and runs like a dream. If I had something other than the K26/6 I would expect to see both of these numbers increase a lot, since the k26 gives up and dies off quick at 5K RPM and flows NO WHERE near the air that John's turbos do. Just a reference for the MAF and quality of the tune for the MAF, HP and Torque curves look perfect, and linear.
Thank you for the feedback!
A quick update for those that are waiting to the last minute. There is only one Stage 2 and one stage 3 left under this promotion.
Thanks.
Thanks.
