Stall then not turning over...
so i did some autox today and the course got wet and i spun the car... it pushed out on the passenger side then all the way around on the driver side, when it stopped moving it wouldnt turn over all the way. it will almost fire up and hit 650 rpm but then drop to 0 i have 2 spare DME relays that i tested and it still wouldnt fire. oh and the engine was real hot to the touch... i couldnt place my hand on the intake.
any tips would help
Dallas
any tips would help
Dallas
Lazer Beam Shooter
any tips would help
Dallas
any tips would help
Dallas
If it was wet outside, try making sure no moisture got in your distrubutor cap.
My bone stock 951 had vapor lock issues at the track when I took it for the first time, it'd barely idle on restart after a run and then die, but if I kept my foot on the gas like a minute or so it'd start idling fine and run great on the track the next session. I started leaving the hood up between sessions to help dissipate the underhood heat and the problem went away.
But, this was on the track where I'm out for 20-30 minutes at a time at high RPM. In an auto-x might not be as likely, but you never know.
i pushed in the clutch... that is why i wondered why it died...
so i pulled the cap off the end of the fuel rail and it just dripped out even while trying to turn it over.
that would be a sigh of bad fuel pump right? or it just isnt getting any power?
Lazer Beam Shooter
Unless youre out of gas....
ok so the fuel pump doesnt turn on when i turn the key or try to turn the engine over. i have 2 spare DME relays that i changed out and still nothing. i checked the fuse for the pump and still nothing.
so the fuel pump is dead? or could it be something else?
you will need to remove the cover for the fuel pump at the bottom of the tank, grab your trusty voltmeter, and check the voltage at the connector while cranking, if you have 12v, and no fuel at the rail, then your pump has taken a dump.
Location: Laguna Hills, Southern CA 88 turbo s silver rose
ill give another + on the distributor cap. Just replaced mine after the exact thing happened minus the spin. going home from work stalled and then wouldnt start again. my cap was all corroded no bueno works fine now though
WOW!! just replaced the fuel filter and pump... the car runs like a champ now... it was stumbling at idle before now strong.
thanks for all the help
Dallas
Dallas
