alternator
Expect a little spark, but if its noticeably larger, it's due to either you having an electrical item on (stereo + amp, fan, ignition is on... anything that draws power)
or you have a wire thats grounding out (alternator power wire (red wire))
Good luck!
Good luck!
ive seen many times people hook up an alternator and while tightening the postive cable they let it rotate and touch the housing. Then they hook up the battery and it pops the fuse for the system.
