Assembly Advice: Ground control camber plates and paragon strut conversions
Old 04-02-2008, 10:31 AM
kasturbo
kasturbo's Avatar
Here is a question for those using the GC hats. Notice the ID of GC hats is a lot larger therefore the hat slides up and down the strut vs. the RE hats that rest on top of the strut shaft with no play. Will the GC hats cause noise and abnormal wear? Seems to me like it would just rattle around. Or do they sit fine once compressed by the spring?
Old 04-02-2008, 11:16 AM
Jeremy Himsel
Jeremy Himsel's Avatar
Once compressed by the spring they're sandwiched between the upper plate and the spring so they're pretty solid. The only time you need to pay attention to them, or hear anything from them, is after jacking up both front wheels.
Quick Reply: Assembly Advice: Ground control camber plates and paragon strut conversions
