Goop under my oil cap?
Can someone please explain this substance? I’m using Mobil 1 10w40 and my coolant level is constant.
It has a slight fuel smell and a very soft margarine texture.
Hi Jason,
that is usually caused by condensation. being in the air/oil seperator you will get quite a bit of moisture in that area. more or less depending on climate and vehicle use. the water droplets mix with some oil in the area and cause this slight milkshake foam
Sean
Sean
Yeah I get some of that in my oil cap also, after a long drive it goes away. I usually try to soak up any moisture in the cap and AOS tube with some paper towels if I am just messing around in the engine bay.
Just checked the oil in the wife's car the other day. Mercedes also reccomends Mobil 1 and I found the same stuff on her oil cap. She freeked, but we have been having the same type of weather Doc was talking about. I cleaned out the cap, took it for a long drive popped the cap when we got home and no gunk.
