should I install a EGT gauge? when i do oil temp gauge
#31
So what about the plug and play EGT kits that were sold on here that plug into the sniffer tube outlet on the crossover.....? Do you have to keep the wire length the same or is there some way to calibrate them for whichever gauge you choose? Otherwise based on what is stated above they are not going to give meaningful results.....right?
