Cam Sprocket Housing Seal Job
I just wanted to verify before I put in my parts order, this is what I will need to fix that pesky oil leak. Thanks
PET Illustration 103-05
#13 1 each Rubber seal 928.105.184.00
#14 1 each Woodruff key (optional) 900.117.045.00
#19 1 each Bolt (optional) 999.510.022.08
#20 1 each Spacer 928.105.139.04
#21 1 each O-ring 999.701.602.40
#22 1 each Seal 999.113.349.40
#23 1 each O-ring (flat mylar washer)
![](https://farm3.static.flickr.com/2091/2231467106_8cee06475a_o.jpg)
I have never seen 13 when I do the job. I guess I completely forget to even look for it. But I always end up with that piece left over.
I think the kits the Paragon, etc. sell include all of the necessary seals including the tower gasket (#3) and access hole seals (#6).
A couple words of caution/advice. Don't strip out the cheesehead bolt (#19). It's grade 10.9 and a bitch to drill the head off (BTDT). You will have to counter-hold the cam w/ a large wrench as that bolt is on tight. Whack the head a couple times w/ a hammer and punch to wake it up.
Also, my mylar washer (#23) was fused to the cam. Almost overlooked it and had to scrape it off w/ a screwdriver.
LOL, I knew I'd get questions about the avatar. It's some guy from www.hotchickswithdouchebags.com and I thought he would look funny with the nuke note.
Clearly, judging by the flash of light (note his shadow on the wall, the whooshed-back hair, and burned skin) this is during the blast.
Dan - dangit! I just always overlook that one and at the end of the day, I'm looking at that piece thinking where the hell it goes. I wonder if someone has real a pic of it, on the engine.
Another tip I forgot to mention.
The 'connecting piece' in Bruce's picture was stuck in my case. I tried to pull and turn it w/ vice grips to no avail but roughed up the surface in the process. After I tapped it inward with a hammer, it broke free and I could pull it out w/ my fingers.
Can you change these seals with cam tower still attached or timing belt rear cover in place? I'm doing this right now and it seems that I cannot remove the part #15 because rear belt cover is on the way. I'm afraid cover will break if I bend it enough to pull the cam sprocket housing.
I'm changing just the front seals. Other cam tower gaskets were done 2k miles ago, so I'm a bit lazy here. I thought I could do it with cam tower and rear belt cover in place because I followed the Clarks procedure:
http://www.clarks-garage.com/shop-manual/cam-03.htm
