330 HP with AFM?
Quit Smokin'
I dont mean to sound sour, but it doesn't sound like that big of a challenge. 15% driveline loss at 330 crank horse nets 280 rwhp, and 15% is probably generous. If you meant chipping and turning up the boost on a bone stock 86-88 non S turbo, then it would be pretty hard.
Per your question, IF the only stipulation is stock AFM then an 89 S with 3" exhaust, wastegate, and chips could probably get to 330 CRANK hp with little trouble. LR sells a 270RWHP out of the box for the S cars. I would think pushing past that threshold might start to get tricky
Drive-by provocation guy
I simply want to know if a 951 engine with stock AFM was able to produce more than 330hp.
That example you mention would be interesting to do with AFM and then swap in MAF and see the direct results of the increased CFM of the MAF vs. the AFM. Just to see how much the stock AFM was choking out the flow.
Trap speed is indicative of STRICTLY hp, practically speaking.
Before learning to tune and having more brain cells, I did 282 rwhp but it was so rich with the old Kokeln chips that I could not get rid of the black smoke. If I could have cleaned it up, I feel confident it would have a bit more; 18psi.
