Rims for 2" Widebody?
I have actually payed for custom 3 piece rims and all, but haven't given the guy the measurements
I have early offsett 86 arms now, but will go wider for the widebody so less stress on hubs.
I can calculate the correct ET needed from the 18x8 and 18x11 setup I now have, but then I would need to know how much more 87+ builds, has anyone got the numbers? what do you guys with 18x11' on 87+ run of ET?
Yeah I know. It's some freaky midnight ritual at the start of the fishing season or something. hahah
Doug does your rear stick out just a little too much for a road car? Plus what about those sizes that you quote and Guns does too? From what I can find out we need sizes more close to each other front and rear to combat understeer and even out tyre heat front and rear. I am looking at more like 11's f and 12's rear and not having more than 30 or 40ml at the very most between the tyre widths. I am thinking more like 295s f and 315's rear. kiyokskia, you will have to be careful of the same problem if you only increase your rears. You will more than likely have BIG understeer.
just need to give the guy the specs so I can order the wheels and build from that.
I would wait until you have the body kit and test fit it and then do the wheels.
pm sent.
pm sent.
