escort cup question
Funny how the brain ages. At first the Escort Cups seemed like a way to upgrade without touching the t-bars. But then I noodled through the "loaded/unloaded" thing and realized it was not going to eliminate the problem. So I was leaning back toward the Koni solution.
BUT, yanking the t-bars is a one-time, low-intellect activity (the real big-brain stuff is in the fine-tuning), so I can yank them and be done with it. So now I'm back on the Bilstein bandwagon. Until I have the next revelation.
I am running the bilstein cups with 400/600lb springs (F/R) on my 951 without T-BARS. This is my track car and I have not had any problems. The real issue with removing the T-BARS is with the compression/stress forces that the rear sees when it is slammed at high speeds over bumps (i.e speed bumps, potholes) .
Gonna chime in here, why is it that I never hear of anyone using the Firehawk set-up? Been on the fence as to what to buy when it comes time, but never hear anyone speak of this option. Is there a reason?
If you're not racing full on why do you need to remove the t-bar? Who amongst you is going to change their rear coils on a regular basis?
From what I hear, getting the rear bars properly set up even once is a bear of a job. So, if one suspension job involves simply removing the t-bars, and another involves replacing and adjusting them, then you would favor the former job, all else being equal. I agree, though, that once you set your ride height, you're not going to be doing it that frequently (if at all).
Every time I read about people having to compromise on their suspension between stiff enough to help at the track, yet compliant enough to drive around town, I can only thank the lord that I came upon my KW's. They really do allow you to have both and not feel compromised.
Ok sorry, back to the subject.
