chip questions
i just purchased some autothority chips but i dont know if they are stage 1 or 2... and i dont know how much boost they support. anybody know?
this is what the chips say on top
CARB EO# D-228-1
POR.01.951.220 KLR
CARB EO# D-228-1
POR.01.951.220 DME
thanks
CARB EO# D-228-1
POR.01.951.220 KLR
CARB EO# D-228-1
POR.01.951.220 DME
thanks
I had some autothority stage 2 that had these same numbers. NOT positive this is confirmation though. They could easily have the same numbers considering the application is the same. I really had good results with the chips but beware buying 2nd hand chips, it is a risky business.
I can't confirm, but I don't think you have Stage II chips. Here are pictures of mine when I changed chips:
![](http://i98.photobucket.com/albums/l266/busabkickinbutt/DSC03720.jpg)
![](http://i98.photobucket.com/albums/l266/busabkickinbutt/DSC03719.jpg)
As for boost, I think they supported ~14psi, but I cannot confirm that either.
-Darwin
-Darwin
The autothority stage 1 was just a DME chip for stock boost. The stage two was the DME & KLR chip with the banjo bolt for raised boost. The stage 3 was the MAF kit. According to APE in the mid 90's at least.
If anyone tells you that you "should" be able to turn up the boost any amount, you should smack the crap out of them. Unknown chips + more boost - wide band device, to measure AFR = BOOM!
i am going to use a mbc to control the boost (black *** from LR). the chips are autothority and from what i have heard since i have 2 chips that means that it is stage 2... so that is how i was going to judge how much boost.
