chip questions
01-23-2008, 12:24 PM
Quote:
Originally Posted by
dhall615
i was also told that if i had a mbc i wouldnt need the banjo bolt...
If your using a MBC, then don't use the banjo bolt.
01-23-2008, 12:42 PM
i already have the mbc ... and what i was told is that if you have a mbc you dont need to use the banjo...
01-23-2008, 01:31 PM
here is some information on the Stage 2 program
01-23-2008, 02:36 PM
and the mbc is going to take the place of the banjo bolt and restrict the air flow and create .95 or 1.95 bar of boost... or am i totally off?
01-23-2008, 03:20 PM
that is correct but an mbc does not regulate airflow to the wastegate as accuratly as the cycling valve (15 hz, rectangular wave)
auto ,
autothority ,
carb ,
chip ,
d2281 ,
dme ,
eo ,
eod2281 ,
klr ,
por01951220 ,
por01951220dme ,
porsche ,
thority
