2.7L 89 NA BLock vs. 3.0L S2 Block
Can anyone enlighten me on the differences b/w the 2.7L NA block and the 3.0L S2 block? I tried a search and know the ins and outs of the head, pistons, etc. but I am wondering about the block differences themselves. Are they the same minus the crank and other components?
Thanks.
Thanks.
^ I think so as well but don't know for sure.
I have heard 2.7L blocks lack the coolant drain bolt on the passenger side of the block, near cylinder 4. I don't know if S2s and 968s got these or not.
What about the cylinders? The 2.5ltr is open for 360o around the whole way. The 3.0ltr has 'siamesed' cylinders which some say can create hot spots as the water can't get completely around it, others say that increases the strength.
Plus different water jacket.
I think a good 2.7L engine will be around $1500-2000 (I might be way off). Of course the condition will be a key factor here.
In addition to the cylinders being connected(or siamesed) the base of the coolant cavity is moved up a little over a third of the distance up the cylinders as compared to the 2.5. This is all aluminum so there is definitely more aluminum mass and on the surface it appears the 2.7, S2 and 968 blocks are structually stiffer. As for the cooling aspects the bottom third of the piston travel has less heat to transfer to the walls than the top 2/3. I guess the question is whether there are any indications in the racing world that the S2 and 968 suffer from heat related failures due to these changes relatively more than comparable HP 2.5 cars or even the stock 2.5 turbo class cars.
Yes well I guess that's the question. It seem to be the preferred option of engine builders to go with the 3.0ltr blocks though doesn't it? So I guess they're going for strength over any cooling/heating issues. The main issue with failure is probably still the oiling, which can be affected by heat in some cases too.
