Boost/fuel chart?
Small Business Partner
Ah - must have missed that.
It really depends on ignition timing (as blown said)... you could hook up an LT1/4 knock module. It is a stand-alone piece, and then you would have an idea if your knocking or not. OR even better would be an J&S Safeguard. I've used one before on a supercharged project with very good results. Highly recommend the J&S if its in your budget..
Rogue
Rogue
