Just intalled LR-951-MAX Chips.... Wow
I finally fixed my rough idle problem. That was the last fix-it job I had left so it was time to go faster.
I installed the 951 MAX chips, 3 bar fuel regulator to go with the manual boost controller I installed a few weeks ago.
Wow!!!!!!!!
Power every gear feels great. Accelerating from 60 mph in 3rd gear is supper strong. I had the boost set to peak at 17 psi then I turned it down to peak at 15 psi, just to be safe.
Power in 1st & 2nd gear is better now too. From a rolling start I can now spin the back wheels in 1st and the throttle response in 2nd in much improved.
Wow!!!!!!!!
