can you relocate the ground wires on clutch bellhousing?
i see a perfect spot on the intake manifold for relocation. it is such a PITA trying to put those suckers back into that hole you can't even see under that cluster of factory wires/hoses!
yeah it is a bad spot- i pull the hose for the heater when i need to get back there- then its easy. Not sure i would put it on the intake but im sure there are plenty of other spots it could go.
While you are at it, buy a nice heavy braided ground wire to go from the engine to the firewall. I did this and it cured a bunch of weird electical issues such as flickering lights, odd gauge readings, etc.
