Need turbo parts? 86 951 parts still available!
ok so most of the stuff has left but i still have a ton of parts left hanging around the garage that i need to leave. Dont hesitate to shoot me a PM for parts and i'll do my best to get things out quickly and get cheap shipping etc. Pm is your best way to get ahold of me because otherwise it depends on how frequently i check this thread. Dan.
Interior parts
-Lower is for a seat w/ split uppers -has a notch in it to clear the inner hinges- $35
- full set of front/rear script black seats all very nice- ds front has splitting on the outer bolster - $150 for all- pickup only
-black front headliner panel w/ light- $25
-central lock switch -$20
-ps window switch trim- $10- (ds is broken)
-glovebox door- $10 no arms on it sorry
-gloveBOX- $10
-dash trim to left of steering wheel - i have three! $10 each
-dash trim to right of steering column- $15
do not have dash trim over glovebox sorry
-black a-pillar cover ds only-$30 ds has one screw hole in it-not very noticable
-black rear side panels-around speakers- $10 each ds is kinda warped like it was shipped to the PO at some time but ok
-black rear hatch SIDE carpet- has holes for late car shoulder harnesses-$30 both w/ light
-black carpet-front and rear- $65 obo
Engine /suspension parts
-bellhousing-$35
-crossmember-$35
-stock regulator- $10
-stock wastegate - $50
-wastegate braket- $15
-radiator fans/motors- x2- $30 each -no shroud
-IC hardlines stock painted black- $15 each- two Turbo-->IC
-power steering pump-remanufactured labelled on side- $40
-ps resevoir -$10 w/ cap
-clutch master/slave- $20 both
-ps cooler hardlines-$20
-a-arms early offset- $65each rebuilt w/ greasable fittings Passenger side only!
- turbo axels- $20 each
-torque tube- $40 pickup
-alternator works fine- $70
-N/A trans- less than 100k- from 87 944 - $450
Body
-ps fog w/ lense has a rock chip hole- make offer
-turnsig ds lense-is old looking- $10
-power headlight assy- buckets,motor,linkages-$75-pending payment
-hatch wiper arm- $15
-hatch release motor- $25
-doors- $25 each pickup only (ds only)
-door windows- $30 each
-ds window regulator - $25
-windshield wipers- $10 each
-rear bumper- $40
-rear bumper side eurethane pieces- $15 each
-ds inner wheelwell- $15 (ps is somewhat messed in the front) SOLD
-license plate braket-rear- $5 w/ bolts/washers
-ebrake handle-black very nice- $30
-wiper motor w/ alumn brace- $45
Interior parts
-gloveBOX- $10
-bellhousing-$35
-crossmember-$35
Body
-rear bumper- $40
i'd have to pull it down and take some pics - the carpet is in very good shape- i believe it was from a 968 since alot of the parts in this car were from a 968 also. Just needs vaccumed up alittle- only catch is the front section was split down the center under the console which really just makes it easier to install- you cannot tell after the console is in though.
