Factory Suspension Bushing Replacement?
I'm in the process of rebuilding a 86 951. Under inspection the suspension bushings are worn and require replacement. From browsing it seems the Weltmeister offers poly-graphite bushings. Does anybody have any experience with the Weltmeister bushings? Do they squeek like the polyurethane bushings..that require constant lubrication? Are there any other companies I can go with?
Side note. I paid for a 1 year membership. How long till i'm recognized as a member?
Weltmeister doesn't make poly bushings for the stock 944 sway bars. You can get Racers Edge Delrin bushigns for some of the bar sizes:
http://www.paragon-products.com/Sear...elrin+sway+bar
Unfortunately the 86 951 has a different size front bar than the other 951's and Racers Edge doesn't currently offer that size. The stock ones are kind of pricey for rubber:
http://www.paragon-products.com/Prod...2Dlate&CartID=
Customers always ask me if that price is a typo...it isn't.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
so i don't have to start another thread....
Reasearching the archived threads on control arm solutions i've reallized that the 86 951 can replace their front a arms with the steel arms from the 83-85.1 models. Is this true? The reinforcement, as provided by Blaszak precision motorsports, is to reinforce the sway bar mounting point. I ask because I can't get a hold of Blaszak. If it's a simple bolt-on solution I'd rather reinforce it myself, and use this as cheaper solution.
thanks again
thanks again
abit more searching and i found the answer.
https://rennlist.com/forums/showthre...l+control+arms
944, 951, bar, bushing, bushings, bushingsa, replacement, suspension, sway, turbo, weltmeister, worn
