Steering/Suspension Question
Basically when I accelerate (can be just a small acceleration) the car goes to the right slightly and when I let off goes back to left slightly. The steering wheel doesn't move when this happens. What do you think is the most probable cause? Someone told me it could be the rear causing it also but doesn't seem like it to me.
I might just replace wheel bearings, control arm bushings & ball joint, and tie rod ends. Has stock suspension and power steering still.
John
John
If it is the tie rods, i should be able to just replace the ends right? not the whole bar assembly?
I was thinking about getting the Rennbay ball joint repair kit, Anyone have any input on that kit or any kit for that matter
John?
John?
