Help me find reasonable power
after following this thread I would like to emphasize the importance of being able to monitor your air/fuel ratio. I can't believe there is any 951 owner that wouldn't endorse and encourage this. Regardless if you have a wideband or not you should understand the importance and be working to somehow being capable of monitoring such vitals if longevity is any kind of concern. Even on a stock 951 I am confident in saying this investment would have a profound effect on extending the life of the engine. These cars not only are high performance vehicles but they are 20+ years old, combining the two we all know dozens of possibilites that could mess up our air/fuel and you'd never see it coming. I was guilty as charged. All I wanted to do was buy upgrades until someone smarter than I talked me into saving up for a wideband first. My car was stock and I found out I was way lean due to dirty injectors, I could only guess how long I would have lasted with some appealing mods. Not looking to argue, just trying to share some experience.
![order](https://rennlist.com/forums/graemlins/order.gif)
Back to an earlier question...for those who have installed a tial38 WG does this http://us.europartsetc.com/inventory...y=&catalogid=1 contain everything I will need to properly install it? And what spring rate do I want in the WG? I see they are offered with different spring rates. TIA
So if I did:
Tial 38 WG
Adj. FPR
951Max chips
MBC
WBO2 sensor
I could run 15 psi relatively safely (with a proper tune)?
In the future if I chose to up the ante again, would those mods support a larger turbo, larger injectors, with a chip reprogram (maybe even a MAF)?
Just trying to be smart about this...
Tial 38 WG
Adj. FPR
951Max chips
MBC
WBO2 sensor
A WBO2 is mentioned three times within the first 4 post "panther", including yours.
"A fool and his money soon part" upgrading performance without a WBO2 is risking the hard dollars you just invested. Might as well take it to Vegas.
A larger turbo, MAF package, often include or exclude injectors, which you'll need at that point. However, with the AFPR, Wastegate, MBC, WBO2 - all of that can be used with any future upgrades; 2.5 - 3.2L.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Jim-
I made 250rwhp and 270rwtq with 2 1/2" exhaust, no cat, MAF, stock turbo, mbc, dual port wastegate, afpr, and bigger injectors (no added hp there) at 15psi. I had Vitesse chips tuned for the injectors and MAF. Could have squeezed some more power out of it had I realized the port on the bottom of the throttle body had blown off the cap I zip tied on causing a vacuum/boost leak.
Jim-
I see in your sig that your car sold, congrats!
Jim, after having open dump I think everything other than cup cars are "stock exhaust" ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I'll be back in Rochester at some a week or so from Monday, give or take,
hahahaha. I know I have a spare, make me a fair offer and it's yours. Sitting in my toolbox if you wanna just go get it or you can wait till I'm there.
Rocket Scientist
When looking for a Tial, buy from anywhere. But I'd suggest picking up a set of copper/metal gaskets like SFR offers. The paper gasket that Tial supplies with the W/G is junk as far as I'm concerned. I've been through my fair share of them. With the added heat on a track car, I wouldn't waste my time with the paper gaskets.
