Water tube mod with SFR stage II headers
Old 05-20-2010, 09:53 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Originally Posted by gt37vgt
ah drill another hole in mount then cut the old hole off
Hmmm…cutting a hole off…sounds difficult!!
Add another bung and just plug the old one with a NTP plug.
If the pipe is hitting the headers add a spacer under the pipe mounting arm. Get some longer bolts and piece of thick will pipe with same ID as the od of the bolt. Cut length to fit!
You can just add the spacer to the rear mount if you want to keep the stock rubber hose on the front.
Old 05-20-2010, 10:47 AM
Duke
Duke's Avatar
Ahh the cultural differances. Luckily I've been to both your continents and my guess would be that he suggests cutting the tab of the water pipe and drill a new hole closer to the pipe to mount it closer to the cam housing
Old 05-20-2010, 11:17 AM
gt37vgt
gt37vgt's Avatar
struth criky gingos blyme bugger thanks for translating Duke ..
Old 05-20-2010, 11:30 AM
Chris White
Rennlist Small
Business Sponsor
****** twit convicts can't even spell Crikey right....
(me mum is a limey)
BTW - all machinists want a can of hole remover...it would be pretty handy!
Old 05-20-2010, 03:38 PM
Darwantae951
Darwantae951's Avatar
Quick Reply: Water tube mod with SFR stage II headers
