I want an AIR splitter, but...
I'm afraid i'm going to destroy it on the roads here in new england. Has anyone found a way to reinforce it, or is it just a lost cause? I've seen ads for front lip protectors, like the boomerang or scrape bars. Do you think something like this could work?
Performance products has some for other porsches, but nothing for the 951. I've included a link. My car is at the body shop, and I have no idea where the frame goes in the front... Is it possible to fab some skidplates and protect the AIR splitter a bit?
http://www.automotion.com/ProductCat...&cid=4&sid=307
resident n00b
if you search i think mike (MPD47) had his done, you can do it yourself with some fiberglass resin & cloth.
I broke mine last week, and luckily the bolts i used to hold it on we on the small side & they all popped off, so it didn't get too damaged.
I don't know much about reinforcing these, but i would imagine the front lip of the splitter gets worn & adding filler to the inside would prevent it from spitting open.
I think the reality is, yes, it breaks, so if you get one you can figure on replacing it, possibly a few times depending on your luck.
GT Racing splitter.
It doesn't look quite as good, but has more clearance. I have yet to scrape mine. I have had both in the past and prefer the GT Racing one.
resident n00b
I think my car is lowered 1.5" in the front & 2" in the back sitting on 500 & 600lb springs
Here her pretending its a lawn mower.
I use zipties on the sides to hold mine on. I've scraped it pretty hard on some driveways and it will blow off the zipties but the splitter stays intact. Carry a good supply of spare zipties with you so you can replace them after a good scrape.
I could not live with a splitter, but if I had to I would look into something like motorcycle frame sliders bolted in behind the splitter to hopefully keep from bottoming onto it so easily. Delrin busings maybe.
-Joel.
-Joel.
Making something that is malleable and just wears away to it's natural level would be ideal. Some sort of rubber like the rear spoiler is made out of.
pic of the GT racing splitter on my car.
![](http://forums.rennlist.com/upload/gt_racing_splitter.jpg)
I thought I was the only one that did that! I bumped into a curb once and when I got out the entire splitter had been knocked off and was laying on the ground. Every zip tied was broken but the splitter was intact and not even cracked anywhere! Just threw it in the hatch, went home and zip tied it back on. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I've lost one that was zip tied on at 140+ before, I had the same idea, that was one of my first ones. I'm on #6? #7? Not sure. I kept blowing through them. They'd tear at usually the same spot, and as I bought 4 or 5 in one blow once, plus a couple semi damaged ones from another lister I just slapped new ones on. Here's my last one:
![](http://www.mturck.com/Nyspeed/DSCF4406.jpg)
The new one is reinforced with ballistics grade carbon kevlar (friend had some "sitting around" that he wanted to use up
). Also lining the bottom of the car with aluminum sheet so it'll keep it from splitting at the usual place up top, and keep it from rubbing through on the two usual outside places. 9 times out of 10 it'll either rub through in the front two corners causing the bottom tray to separate or split at the same between the tray and half way up the actual lip. Hold your "new" unit up to a decent light source you can see where they bonded the pieces together.
![](http://www.mturck.com/944/March07/DSC7970.jpg)
That's the cosmetic "nice" looking stuff. The ballistics grade stuff is a bright gold under it and towards the center of the piece. As per your question, if you're careful you can get away with 1 splitter every 12-18 months. But you WILL scrape it up.
thanks for all the replys guys. Im not too worried about scraping... I can always just add an aluminum or rubber plate to the bottom. Im more afraid of bottoming out and leaving the splitter sitting in the middle of the road, or just splitting it in half.
JustinL and 87944turbo, Your splitters are held on with just zipties? sounds kinda flimzy. I guess i'd have to see it, but it sounds like it works in practice.
I'd have to have my guy paint it, then let me install it later, because there's no way i could leave his shop without ripping it off. I scraped coming in, and it's stock height with no batwing. it's a good 50 degree incline up to his garage.
