What does a 2.5L engine weigh?
resident n00b
Shipping a dry / complete 2.5L w/ crossover, turbo & intake attached.
What does it weight ? (estimation is fine)
just an fyi, if your not shipping it by air then round down, the prominent shippers really don't care about pounds when it's on the ground as much as dimensions so if you can get it on something smaller than a standard size crate you will save the most, also if you can't ship it to a bus address then have them hold it at the station. it can cost you an extra $300 for resi delivery depending on loc.
Any of you have recommendations on shippers that will do one piece within the US? I havea 150 lb traans on a palate I need to go to New Jersey. FED EX WANTS $570!
TIA
TIA
www.freightquote.com register and find a drop off terminal to drop off terminal, much cheaper or if you have a friend with a business that has a forklift.
570... is that fex ex ground?? UPS is alot cheaper, cut the pallete in half, make sure it's no more than 150 and send it to a bus. address or hold at station. less than 3 bills.
Basic Sponsor
406.9lbs with a k-26
Basic Sponsor
If your looking for a shipper try www.forwardair.com
I shipped an NA 2.5l a couple of months ago for about $200 or so dollars through them.
